Export image from completed PBR?
JBi-PDX
How come when I finish a PBR (200 passes) and then go to export the image, it starts the process all over again? Am I missing something? I would think that when it's done, it's done and I can just export the finished product as a PNG.
Thanks.
Jason
Idk, it doesn't do that for me. It blinks for half a second but does not restart the PBR. Are you going to File > Export > Export Picture?
Do you have "use active window size" checked in the export picture dialog box?  If you don't and you are using some other image size, then I think the program will always need to create the image again at the size you set.  If you are using the active window, then it shouldn't need to.
I've tried it with "use active window size" and without "use active window size" checked and it always starts over. I must have something checked somewhere that causes this.
From Chief tech. support - "Initiating the export process is effectively creating a new camera view, similar to moving the camera in a PBR view, where everything must resolve again, so there is no way to export the image as such."
