Ed_Orum Posted February 5 Share Posted February 5 Is there a way to merge two different plans into one plan so I have only one plan in the Layout Referenced Files? Thanks in advance, Lane Link to comment Share on other sites More sharing options...
Doug_N Posted February 5 Share Posted February 5 so far as merging two plan files, I don't think so, but you can have two plan files merged using reference layers in a layout file. Link to comment Share on other sites More sharing options...
JKEdmo Posted February 5 Share Posted February 5 Can you use Edit Area (All Floors) to copy-in-place the content of one plan into the other? Link to comment Share on other sites More sharing options...
Doug_N Posted February 8 Share Posted February 8 That can be done, but it has the disadvantage of using the defaults of the plan file that one is pasting to. So if rooms from the copied plan has different floor heights, the and the pasted building is using default room heights, then the pasted building inherits the native heights. Link to comment Share on other sites More sharing options...
Rookie65 Posted February 8 Share Posted February 8 Might just be safer to send both plans to the same layout. Then any changes to one don't affect the other. That's my 2 cents anyway. 1 Link to comment Share on other sites More sharing options...
Ed_Orum Posted February 15 Author Share Posted February 15 That's what I did, send two plans to the same layout. It worked. Link to comment Share on other sites More sharing options...
