Ed_Orum Posted Sunday at 07:02 PM Share Posted Sunday at 07:02 PM Is anyone else having a problem with the Automatic Foundation Tool? From Floor 1 Build>Floors>Foundation>Build Foundation Walls With Footings Hit Enter Then "Derive Foundation Foundation From 1st Floor?" message appears. Answer: Yes then hit button, the screen switches to Floor 0, but the screen goes blank. I turned on Show All Layers, and the screen still is blank. Anyone else? Thanks, Lane Link to comment Share on other sites More sharing options...
DBCooper Posted Sunday at 08:37 PM Share Posted Sunday at 08:37 PM My guess is that you don't have your walls on the first floor properly defined/connected. If you don't have at least one room, you will not get any foundation walls. Could be other things too so if this doesn't help, you probably want to post your plan. 1 Link to comment Share on other sites More sharing options...
Ed_Orum Posted Monday at 01:38 PM Author Share Posted Monday at 01:38 PM Thanks, so far it is only one room, and the walls are closed, so that's not the problem. Here is the plan: For Upload.plan Link to comment Share on other sites More sharing options...
Solution Chrisb222 Posted Monday at 01:52 PM Solution Share Posted Monday at 01:52 PM 12 minutes ago, Ed_Orum said: Here is the plan: Open the Room specification and check Build Foundation Below: Link to comment Share on other sites More sharing options...
Ed_Orum Posted Monday at 02:19 PM Author Share Posted Monday at 02:19 PM Thanks, I must have turned it off trying to make it a slab on grade foundation. It works now! 1 Link to comment Share on other sites More sharing options...
