PitMan71 Posted 7 hours ago Share Posted 7 hours ago (edited) Is there a way to suppress the "CL" for the centerline dimensions and keep the centerline extension? OR Control just the size of the CL mark? I like it BUT the mark can clutter the drawings. Thanks Shane Edited 7 hours ago by PitMan71 Link to comment Share on other sites More sharing options...
Chrisb222 Posted 3 hours ago Share Posted 3 hours ago 4 hours ago, PitMan71 said: Is there a way to suppress the "CL" for the centerline dimensions and keep the centerline extension? Yes, uncheck Mark as Centerline: 4 hours ago, PitMan71 said: OR Control just the size of the CL mark? The size is controlled by the text size of the dimension text. So yes it can be changed but all other dimension text will also change. Link to comment Share on other sites More sharing options...
PitMan71 Posted 3 hours ago Author Share Posted 3 hours ago Thanks for the reply. I am aware of that setting BUT I want to keep the centerline extension. When I turn off "Mark as centerline" the extensions change to continuous lines. May be a limitation. I might look at changing my overall dim text height. Link to comment Share on other sites More sharing options...
DBCooper Posted 2 hours ago Share Posted 2 hours ago Unchecking "mark as centerline" should keep the extension and just remove the CL text: Link to comment Share on other sites More sharing options...
