LaurenMDB Posted 10 hours ago Share Posted 10 hours ago Hi there. I am working on a plan and I can still see it in layout, but cannot find it in plan view or with a camera. I've never had this happen before and keep looking through forums to see if there's a "focus" button, but I've come up with nothing. Can anyone assist? The plan is also 35.5 MB and it's a basic shell (but too big to upload here) - anyone have a wild guess as to what has happened? I'm using 27.3.2.5 macOS ARM. Chief Architect Premier X17 Thanks! Lauren Kyron 1.14.26.pdf Link to comment Share on other sites More sharing options...
DBCooper Posted 10 hours ago Share Posted 10 hours ago The closest thing to a "focus" button is F6. If that doesn't help, then I am guessing that you switched to a layer set with things turned off. If neither of these help, then you really need to post the plan. Try zipping it up to see if it will be small enough to post or post it on an online location and then put a link here. Link to comment Share on other sites More sharing options...
Solution Chrisb222 Posted 9 hours ago Solution Share Posted 9 hours ago 46 minutes ago, LaurenMDB said: see if there's a "focus" button That would be the Fill Window Building Only tool, which zooms the view to the entire building, regardless of where you were focused. In the OOB template, it's on the right-side toolbar, shown here: Or, it could be something to do with layer settings but that's difficult to diagnose without having the plan file. Link to comment Share on other sites More sharing options...
LaurenMDB Posted 7 hours ago Author Share Posted 7 hours ago Thank you both! 1 Link to comment Share on other sites More sharing options...
