Exterior Walls Not Recognized In Full Overview
kdaleyates
I can't figure out what is wrong.  I have drawn a house with brick exterior walls however when I view the house in full overview, then I try to select an exterior wall it ignores the exterior wall and highlights the interior room instead.  Also, the exterior wall brick pattern does not show up when I send an elevation to layout.  Can someone let me know what is wrong?  Thanks
Dale
Prefs for select walls before room (image one)
You need to adjust the color of the grout lines for your brick. They are most likely currently white mortar lines. When you send an elevation in vector view you are losing the color (red) for the brick and only showing the grout lines in white which are disappearing in your white background. (Image 2)
