para-CAD Posted Tuesday at 12:57 AM Share Posted Tuesday at 12:57 AM It's never worked for me since 2015. Is it a mac setting? Link to comment Share on other sites More sharing options...
Eric_S Posted Tuesday at 06:29 PM Share Posted Tuesday at 06:29 PM Mac spell check does not flag words written in all caps as incorrect. I believe this is general behavior across multiple Mac applications. 1 Link to comment Share on other sites More sharing options...
rwdozier Posted Tuesday at 08:29 PM Share Posted Tuesday at 08:29 PM FWIW - AI says... You spotted a real and very common behavior — and yes, both Windows and macOS (and most browsers and apps) often do NOT spell-check words typed in ALL CAPS by default. And your screenshot clearly shows it: BECASUE (all caps) → no red underline becasue (lowercase) → red underline Let me explain why this happens and what you can do about it. Why all-caps words are often NOT spell-checked Most operating systems and applications intentionally skip spell-checking all-caps words because historically: 1. All-caps are usually treated as acronyms Programs assume that text in ALL CAPS might be things like: NASA CPU HTML USA ASAP To avoid false warnings, developers traditionally disable spell-check for all-caps strings. 2. Many documents use all-caps for headings or emphasis If spell-check underlined every title like: IMPORTANT INFORMATION TERMS AND CONDITIONS …it would annoy users and clutter the screen, especially in older word processors. 3. Legacy behavior from early word processors This tradition dates back to: WordPerfect Microsoft Word 95–2003 Early macOS text systems Those programs defaulted to treating ALL CAPS as “don’t check” text, and the behavior has stayed for consistency. Apps & systems known to skip spell-check on ALL CAPS Microsoft Word (unless you disable the setting) Windows spell-checker (system-wide) Chrome/Edge browser macOS system spell-checker (Safari, Notes, etc.) Most email clients This is normal and expected behavior. How to enable spell-check for ALL CAPS (if you want it) Microsoft Word Go to File → Options Choose Proofing Uncheck:✔️ “Ignore words in UPPERCASE” Word will then underline misspellings in all caps. macOS (system-wide) macOS provides no built-in toggle, and many apps do not check all-caps text. Some apps (like Pages) do check all caps, but browsers and text fields usually do not. No universal fix. Web browsers (Chrome, Edge, Firefox) There is no settings toggle to force spell-checking on ALL CAPS in the browser text fields. It depends on the underlying OS dictionary. Conclusion Your screenshot is behaving exactly as designed. Spell checkers skipping ALL CAPS is a longstanding convention meant to avoid flagging acronyms, technical terms, and headings. If you want it checked, Microsoft Word lets you enable the option — but browsers and many system text inputs still won't. 1 Link to comment Share on other sites More sharing options...
para-CAD Posted Wednesday at 01:15 AM Author Share Posted Wednesday at 01:15 AM YESSSS!!! Thank you both for reminding me of the all-caps thing. All my plan text is ALL CAPS Arial. I guess I could start doing sentence case and then select all and press the Aa button. Thanks again, gents. Link to comment Share on other sites More sharing options...
tundra_dweller Posted Wednesday at 01:51 AM Share Posted Wednesday at 01:51 AM The Anycase app is a fantastic tool for changing text case quickly after the fact. https://anycaseapp.com/ Thanks to @Alaskan_Son for bringing attention to this app. I don't think it does spellcheck though. Link to comment Share on other sites More sharing options...
