Drew-PRH Posted November 14, 2025 Share Posted November 14, 2025 Is there a way to create cafe doors? I can not figure out how to make any door panel smaller while maintaining a standard door opening. Thank you - Drew Link to comment Share on other sites More sharing options...
Rookie65 Posted November 14, 2025 Share Posted November 14, 2025 I think there's a bonus catalog (specialty doors) that may have cafe doors Link to comment Share on other sites More sharing options...
Drew-PRH Posted November 14, 2025 Author Share Posted November 14, 2025 I will scroll through that again - I may have missed that. Link to comment Share on other sites More sharing options...
Drew-PRH Posted November 14, 2025 Author Share Posted November 14, 2025 18 minutes ago, Rookie65 said: I think there's a bonus catalog (specialty doors) that may have cafe doors Thank you - Doors No.3 Specialty are more of what I might call saloon doors and others not really suited for a kitchen pantry. Looking to adapt a 1-panel. Link to comment Share on other sites More sharing options...
ericepv Posted November 14, 2025 Share Posted November 14, 2025 Here''s a symbol I found on 3D Warehouse... https://3dwarehouse.sketchup.com/model/af5ddf24f638a55de1eaadd907cc5148/Cafe-Doors The important thing to remember is if you classify it as a fixture when you import it into Chief, you can easily control the position of the doors when you place it in a doorway. If you classify it as a door then you will need to delete the casing and jamb so that you are left with just the door to position in a previously placed doorway. Link to comment Share on other sites More sharing options...
DBCooper Posted November 14, 2025 Share Posted November 14, 2025 You can use any door panel symbol you want and then just raise the bottom (by setting the bottom offset) and lower the top (by setting the panel height) so that the panel is smaller than the opening. I couldn't find a door panel that looked like your picture but it should be pretty easy to make one using poly solids or whatever. 1 Link to comment Share on other sites More sharing options...
Drew-PRH Posted November 14, 2025 Author Share Posted November 14, 2025 11 hours ago, ericepv said: Here''s a symbol I found on 3D Warehouse... https://3dwarehouse.sketchup.com/model/af5ddf24f638a55de1eaadd907cc5148/Cafe-Doors The important thing to remember is if you classify it as a fixture when you import it into Chief, you can easily control the position of the doors when you place it in a doorway. If you classify it as a door then you will need to delete the casing and jamb so that you are left with just the door to position in a previously placed doorway. Thank you for the link - great info, and thank you for the explanation Link to comment Share on other sites More sharing options...
Drew-PRH Posted November 14, 2025 Author Share Posted November 14, 2025 10 hours ago, DBCooper said: You can use any door panel symbol you want and then just raise the bottom (by setting the bottom offset) and lower the top (by setting the panel height) so that the panel is smaller than the opening. I couldn't find a door panel that looked like your picture but it should be pretty easy to make one using poly solids or whatever. Thank you - that is what I was looking for. I did fumble around with these setting, however I was not setting the proper dimensions for it to work correctly. That worked GREAT! Link to comment Share on other sites More sharing options...
