Ed_Orum Posted November 13, 2025 Share Posted November 13, 2025 (edited) I am attaching a screen shot of part of my foundation for this particular plan. The windows on the vertical wall and the windows on the horizontal wall show different orientations. The double window line occurs on the exterior side of the vertical foundation wall, and on the interior side of the horizontal foundation wall. Is there a way to install windows backward, or do foundation walls have an interior and exterior side that could be causing the problem? Thanks for any insight. Lane Edited November 13, 2025 by Ed_Orum Link to comment Share on other sites More sharing options...
Ed_Orum Posted November 13, 2025 Author Share Posted November 13, 2025 Okay, got it. I would have deleted this post, but I don't see an option for that. Link to comment Share on other sites More sharing options...
DBCooper Posted November 13, 2025 Share Posted November 13, 2025 Instead of deleting your post, you could always add the answer for the next person that runs into this. Link to comment Share on other sites More sharing options...
Ed_Orum Posted November 21, 2025 Author Share Posted November 21, 2025 I will do so in the future. The answer was user error. Since the window opening spans the foundation concrete wall and the wood frame wall, I was placing the walls in the concrete wall vertically, but on the wood wall horizontally. Once I place all the windows on the concrete wall, the problem was solved. --Lane Link to comment Share on other sites More sharing options...
Chrisb222 Posted November 21, 2025 Share Posted November 21, 2025 On 11/13/2025 at 3:37 PM, Ed_Orum said: I would have deleted this post, but I don't see an option for that. Although I agree you should leave this post up for others to learn from, in the event you do want to delete an entire thread that you created, as the author you should see an option toward the top-right of the thread that says "Moderator Actions" with a pop-up option to delete the thread: Link to comment Share on other sites More sharing options...
