SHCanada2 Posted Thursday at 06:02 AM Share Posted Thursday at 06:02 AM (edited) The roof plane edge will not follow the dimension I give it, it goes back to either what looks like the exterior of the cladding (the walls have 1" exterior foam) or it allow me to move the roof plane into the attcic. The problem is I have to specify to the stud for the truss guys. So I created a little jog on the eave. IS there a trick here? Even if I could move the roof plane to the stud, then the exterior render shows the framing as the roof then cuts the siding and 1" insulation off the elevation view. Even if I use the cntrl key it will not place the edge at 18". maybe because there is an attic wall there? 23.10.2025_00.04.13_REC.mp4 Edited Thursday at 06:09 AM by SHCanada2 Link to comment Share on other sites More sharing options...
Solution robdyck Posted Thursday at 01:46 PM Solution Share Posted Thursday at 01:46 PM Link to comment Share on other sites More sharing options...
PitMan71 Posted Thursday at 10:51 PM Share Posted Thursday at 10:51 PM What Robert said. Gotta uncheck that box. 1 Link to comment Share on other sites More sharing options...
SHCanada2 Posted Friday at 02:55 AM Author Share Posted Friday at 02:55 AM yes that worked, thanks Robert 1 Link to comment Share on other sites More sharing options...
