PitMan71 Posted September 5 Share Posted September 5 Is there a way to set the line defaults in the CAD Detail from View tool? Whenever I use it the line weights are always too heavy and wanted to see if I could bypass having to change all of that. Thanks Link to comment Share on other sites More sharing options...
Solution DBCooper Posted September 5 Solution Share Posted September 5 You can set the default layer set to use in the layer set defaults. I'm not sure why it doesn't just use whatever layer set you are in since then it would be more wysiwyg. 1 Link to comment Share on other sites More sharing options...
Chrisb222 Posted September 5 Share Posted September 5 (edited) 1 hour ago, PitMan71 said: Is there a way to set the line defaults in the CAD Detail from View tool? Whenever I use it the line weights are always too heavy and wanted to see if I could bypass having to change all of that. Thanks Shane, go into Defaults and set the layer properties for the various views. CAD Detail From View of Elevations will use CAD_ Default_Lines and CAD_ Default_Patterns layers. Edited September 5 by Chrisb222 1 Link to comment Share on other sites More sharing options...
Chrisb222 Posted September 5 Share Posted September 5 49 minutes ago, DBCooper said: I'm not sure why it doesn't just use whatever layer set you are in since then it would be more wysiwyg. I actually don't want the line weights to be the same as the view the detail is made from, and so these unique layer sets can be customized to produce the desired results automatically. Also, some views need a special layer set since the feature converts the model and other objects that otherwise don't have CAD-like line settings into CAD using special layers mentioned above, and those layers can be preprogrammed with the line settings you want. The OOB template doesn't even have those layers in the ALDO, they're created automatically when a detail view from say an elevation is created. Fun fact: when a CAD Detail from View is first made from a plan view, layers "0" and "Defpoints" are automatically created, with nothing on them. Link to comment Share on other sites More sharing options...
PitMan71 Posted September 5 Author Share Posted September 5 Thanks.... I am drawing some basic details and this will help. The line weight is set to 50 in some of the lines like drywall lines in a wall section which makes no sense. Link to comment Share on other sites More sharing options...
PitMan71 Posted September 5 Author Share Posted September 5 1 minute ago, Chrisb222 said: CAD Detail from View is first made from a plan view, layers "0" and "Defpoints" are automatically created, with nothing on them. Reminds me of the Autocad days.... Oh wait I am still living in those days. Link to comment Share on other sites More sharing options...
PitMan71 Posted September 5 Author Share Posted September 5 Thanks for the assist guys.... Today I awarded solution to DB because he used the term "wysiwyg" and he was first to the party. For real though, thanks for the help. Helps to have help to navigate Chief and its many facets. Link to comment Share on other sites More sharing options...
