BDG2244 Posted Tuesday at 02:28 PM Share Posted Tuesday at 02:28 PM Hello Chief Community! I am trying to show electrical outlets within the Wall Details that are generated with the wall framing. I have 'Electrical' checked to display on the Active Layer Set, but nothing shows. Is it possible to have outlets displayed on these details? I appreciate your insight! Using X17 Link to comment Share on other sites More sharing options...
Solution Joe_Carrick Posted Tuesday at 04:22 PM Solution Share Posted Tuesday at 04:22 PM No, This is a special CAD Detail automatiallly generated by the software that only includes framing members. The electrical outlets can only be displayed on a wall elevation, not on a wall detail. I think it would be cool if they could but it's not possible at this time. 1 Link to comment Share on other sites More sharing options...
BDG2244 Posted Tuesday at 04:39 PM Author Share Posted Tuesday at 04:39 PM Thank you for the clarification Joe - I will look at creating wall elevations to show the electrical Link to comment Share on other sites More sharing options...
DefinedDesign Posted Wednesday at 10:59 PM Share Posted Wednesday at 10:59 PM On 9/2/2025 at 12:22 PM, Joe_Carrick said: The electrical outlets can only be displayed on a wall elevation, not on a wall detail. I would use this feature for every build! I could use it today! Link to comment Share on other sites More sharing options...
tommy1 Posted 23 hours ago Share Posted 23 hours ago Here is a work around option if it would help. Once you have your electrical done, make a copy of the plan. Open the copy and change the wall types to not have drywall. Be sure to frame the wall or walls. Take a render or elevation and see what you get. My image is an elevation. Link to comment Share on other sites More sharing options...
