BDG2244 Posted September 2, 2025 Share Posted September 2, 2025 Hello Chief Community! I am trying to show electrical outlets within the Wall Details that are generated with the wall framing. I have 'Electrical' checked to display on the Active Layer Set, but nothing shows. Is it possible to have outlets displayed on these details? I appreciate your insight! Using X17 Link to comment Share on other sites More sharing options...
Solution Joe_Carrick Posted September 2, 2025 Solution Share Posted September 2, 2025 No, This is a special CAD Detail automatiallly generated by the software that only includes framing members. The electrical outlets can only be displayed on a wall elevation, not on a wall detail. I think it would be cool if they could but it's not possible at this time. 1 Link to comment Share on other sites More sharing options...
BDG2244 Posted September 2, 2025 Author Share Posted September 2, 2025 Thank you for the clarification Joe - I will look at creating wall elevations to show the electrical Link to comment Share on other sites More sharing options...
DefinedDesign Posted September 3, 2025 Share Posted September 3, 2025 On 9/2/2025 at 12:22 PM, Joe_Carrick said: The electrical outlets can only be displayed on a wall elevation, not on a wall detail. I would use this feature for every build! I could use it today! Link to comment Share on other sites More sharing options...
tommy1 Posted September 4, 2025 Share Posted September 4, 2025 Here is a work around option if it would help. Once you have your electrical done, make a copy of the plan. Open the copy and change the wall types to not have drywall. Be sure to frame the wall or walls. Take a render or elevation and see what you get. My image is an elevation. Link to comment Share on other sites More sharing options...
