rwaldrondesigns Posted 23 hours ago Share Posted 23 hours ago I have run into this issue many times and have just found ways to work around it, but I'm curious to see if there's a faster/simpler way to do this. I often want to put everything in a room on a lighter line weight and others on a heavier for emphasis. But, many (most?) blocks from the library won't allow this. In the past, I'd explode them and then change the line weight which, of course, creates several extra lines we don't want. Tell me there's a better way that I'm missing! Link to comment Share on other sites More sharing options...
DBCooper Posted 22 hours ago Share Posted 22 hours ago Are you talking about cad blocks or something else? Cad blocks have a setting for either "by block" or "by object" and depending on how it is set will affect your line weights. When it is set to "by block" then you can change the line weight for whatever layer the block is on and all objects should be affected. If it is set to "by object" then each object will use it's own settings so changing the block layer won't affect them. Link to comment Share on other sites More sharing options...
rwaldrondesigns Posted 13 hours ago Author Share Posted 13 hours ago 9 hours ago, DBCooper said: Are you talking about cad blocks or something else? Cad blocks have a setting for either "by block" or "by object" and depending on how it is set will affect your line weights. When it is set to "by block" then you can change the line weight for whatever layer the block is on and all objects should be affected. If it is set to "by object" then each object will use it's own settings so changing the block layer won't affect them. I am referring to the objects from the library (fixtures, furnishings, etc) Link to comment Share on other sites More sharing options...
Chrisb222 Posted 9 hours ago Share Posted 9 hours ago 3 hours ago, rwaldrondesigns said: I am referring to the objects from the library (fixtures, furnishings, etc) You should be able to control that by simply assigning to layers, eg: Washer on "Layer X" color gray, line 10, Dryer on "Layer Y" color black, line 30 Link to comment Share on other sites More sharing options...
