thomhu Posted yesterday at 06:28 PM Share Posted yesterday at 06:28 PM Hello, I am working on a project that is calling out white oak vertical shiplap on certain walls. I'm using a shiplap from the core catalogue and I can make it vertical with the adjust material tool. However, I would like to show the shiplap with a white oak grain while maintaining the shiplap look. I see a white oak material in the library, but spraying it on the shiplap wall eliminates the shiplap lines. What would be the best way? Thanks for your time. Chief x17 Windows 11 Think Station P360 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted yesterday at 06:38 PM Share Posted yesterday at 06:38 PM in the material edit dbx., just use the blend with checkbox and choose any color Link to comment Share on other sites More sharing options...
thomhu Posted yesterday at 06:51 PM Author Share Posted yesterday at 06:51 PM Thanks for the help! Instead of changing the color, I'm looking to change the color to a white oak wood grain look . Would it perhaps be the texture source jpg in the Texture tab in the Define Material tool? Link to comment Share on other sites More sharing options...
DRAWZILLA Posted yesterday at 06:56 PM Share Posted yesterday at 06:56 PM that's what the blending tool does, it doesn't change the texture, just the color Link to comment Share on other sites More sharing options...
robdyck Posted 5 hours ago Share Posted 5 hours ago The Core catalog has 3 shiplap materials with a wood appearance however they aren't great as they really don't look much like any type of wood, much less white oak. So if you can't find a suitable texture in any other catalog, you need to make your own texture by either replacing the texture file of one of the shiplap materials with a texture of an oak panel, or by using the normal map from Chief's material and adding that to a texture of oak. Keep in mind that the original wood texture file will need to be running horizontally to work with the Chief normal map. The texture file and normal map can't be rotated independent of each other using the adjust material tool. I quickly made a material which you can use or inspect to make your own material. SHIPLAP OAK.calibz Link to comment Share on other sites More sharing options...
