WhistlerBuilder Posted 16 hours ago Share Posted 16 hours ago I am having problems with textures being missing in x17. So many different siding types so far seem to be missing the associated texture file and bump map. This is not a problem in the previous version I was using. Any suggestions? Link to comment Share on other sites More sharing options...
DBCooper Posted 15 hours ago Share Posted 15 hours ago Are these chief libraries or user libraries? Did you migrate your core libraries? Did you make sure to update them after? Did you put your libraries into the default location or use a custom one? So many questions with so many possibilities which is why this might also be a good issue for tech support. Link to comment Share on other sites More sharing options...
WhistlerBuilder Posted 15 hours ago Author Share Posted 15 hours ago They are supposed to be basic chief libraries. The material type is there, but the texture file is missing. Link to comment Share on other sites More sharing options...
Kbird1 Posted 11 hours ago Share Posted 11 hours ago 3 hours ago, WhistlerBuilder said: They are supposed to be basic chief libraries. The material type is there, but the texture file is missing. sounds like you had a real bad migration experience so I understand not wanting to try that again but have you tried re-installing the Core Libraries from the Library Menu? Another thing I would try if above doesn't work is manually copying the X15 Textures Folder Contents into the X17 Textures Folder. (in the respective Chief Data Folder) M. Link to comment Share on other sites More sharing options...
