BlueHandle Posted Monday at 07:53 PM Share Posted Monday at 07:53 PM I've tried changing the dimensions in: Edit / Default Settings / Dimension / Dimensions / Number style, as well as click on a room, Open Object, Number style. But no matter what, it always displays the dimensions as Feet, Fractional Inch instead of as Decimal Feet. I've tried this in both X15 and X17 as well as tried a new and existing plan. Link to comment Share on other sites More sharing options...
Solution robdyck Posted Monday at 08:02 PM Solution Share Posted Monday at 08:02 PM 1 Link to comment Share on other sites More sharing options...
ericepv Posted Monday at 08:11 PM Share Posted Monday at 08:11 PM Have you tried editing 'Saved Dimension Defaults'? Edit / Default Settings / Dimension / Dimensions / Edit / Chose your format / Edit / Primary Format Link to comment Share on other sites More sharing options...
BlueHandle Posted Monday at 09:26 PM Author Share Posted Monday at 09:26 PM Thanks @Robdyck, that works. PS: @Ericepv. that does not work. 1 Link to comment Share on other sites More sharing options...
robdyck Posted Monday at 09:34 PM Share Posted Monday at 09:34 PM 8 minutes ago, BlueHandle said: Thanks @Robdyck, that works. You're welcome! Link to comment Share on other sites More sharing options...
