BlueHandle Posted July 14, 2025 Share Posted July 14, 2025 I've tried changing the dimensions in: Edit / Default Settings / Dimension / Dimensions / Number style, as well as click on a room, Open Object, Number style. But no matter what, it always displays the dimensions as Feet, Fractional Inch instead of as Decimal Feet. I've tried this in both X15 and X17 as well as tried a new and existing plan. Link to comment Share on other sites More sharing options...
Solution robdyck Posted July 14, 2025 Solution Share Posted July 14, 2025 1 Link to comment Share on other sites More sharing options...
ericepv Posted July 14, 2025 Share Posted July 14, 2025 Have you tried editing 'Saved Dimension Defaults'? Edit / Default Settings / Dimension / Dimensions / Edit / Chose your format / Edit / Primary Format Link to comment Share on other sites More sharing options...
BlueHandle Posted July 14, 2025 Author Share Posted July 14, 2025 Thanks @Robdyck, that works. PS: @Ericepv. that does not work. 1 Link to comment Share on other sites More sharing options...
robdyck Posted July 14, 2025 Share Posted July 14, 2025 8 minutes ago, BlueHandle said: Thanks @Robdyck, that works. You're welcome! Link to comment Share on other sites More sharing options...
