No Attic Walls, No Basement Floor
Ed_Orum
Go to solution Solved by robdyck,
Good morning,
I have attached a plan file; I cannot get the attic walls or the basement floor to generate.
I placed a 3d polyline in the basement to show a slab, but I cannot do anything like that to show the attic walls.
Curiously enough, the Attic Walls generate above the two decks.
Thanks in advance,
Lane
Cozy Cabin Plan File.zip
The left side gable wall is present but it is invisible. Just click the toggle to make it visible.
This attic wall will be easier to locate in your working plan layer set and in this set, I suggest changing the attic wall layer color to something distinctly different from other wall layer colors.
  • Solution
You can't get a crawlspace floor to generate because of how the Crawl Space room is defined. By default, you have this room set to an Open Below room type. Change this to Slab.
Open the Room Spec dialog:
Hi Ed, Just another couple of notes.  You might want to align your piers with the posts supporting the roof.  You can do that a couple of ways, by offsetting the posts from the railing inwards, or by just adjusting the piers and posts under the deck.
  • 2 weeks later...
