Ed_Orum Posted June 9 Share Posted June 9 Good morning, I have attached a plan file; I cannot get the attic walls or the basement floor to generate. I placed a 3d polyline in the basement to show a slab, but I cannot do anything like that to show the attic walls. Curiously enough, the Attic Walls generate above the two decks. Thanks in advance, Lane Cozy Cabin Plan File.zip Link to comment Share on other sites More sharing options...
robdyck Posted June 9 Share Posted June 9 The left side gable wall is present but it is invisible. Just click the toggle to make it visible. This attic wall will be easier to locate in your working plan layer set and in this set, I suggest changing the attic wall layer color to something distinctly different from other wall layer colors. Link to comment Share on other sites More sharing options...
Solution robdyck Posted June 9 Solution Share Posted June 9 You can't get a crawlspace floor to generate because of how the Crawl Space room is defined. By default, you have this room set to an Open Below room type. Change this to Slab. Open the Room Spec dialog: Link to comment Share on other sites More sharing options...
Ed_Orum Posted June 9 Author Share Posted June 9 Thanks so much! 1 Link to comment Share on other sites More sharing options...
Doug_N Posted June 9 Share Posted June 9 Hi Ed, Just another couple of notes. You might want to align your piers with the posts supporting the roof. You can do that a couple of ways, by offsetting the posts from the railing inwards, or by just adjusting the piers and posts under the deck. Link to comment Share on other sites More sharing options...
Ed_Orum Posted June 23 Author Share Posted June 23 Thanks Doug! Link to comment Share on other sites More sharing options...
