capitaldesigns Posted June 9, 2025 Share Posted June 9, 2025 I'm working on a kitchen where I have 15 recessed lights. I cannot turn on all 15 lights at the same time in a perspective view. Only 8 lights will come on at one time. If I select several lights that are turned off in a perspective view and turn them on, several other light will turn off. In X16 does CA only allow 8 recessed lights to be turned on at time? Thanks, Mike Link to comment Share on other sites More sharing options...
DBCooper Posted June 9, 2025 Share Posted June 9, 2025 Open the camera dialog and look at the "lighting" section. See if your maximum number of lights is set to 8. If so, then change it to something larger than you need. Link to comment Share on other sites More sharing options...
Hoff_Design Posted June 9, 2025 Share Posted June 9, 2025 ...or go to camera specifications and change setting from automatic to "light set". The default Light Set will turn on all lights.... or you can create your own light sets and force them to be on. Link to comment Share on other sites More sharing options...
