Gawdzira Posted yesterday at 03:10 AM Share Posted yesterday at 03:10 AM In this file I have one detail. This was copied over from a file where I keep pages of details. If I try to group select this detail and copy/paste, the text jumps to a new location far, far away. If I block it together and then copy /paste and then unblock, all is well in the universe. Any ideas on why this is happening? X16 files. This is happening when copying to a new file or within this file. The detail was created in older versions and has been modified many times across several versions. detail test.plan Link to comment Share on other sites More sharing options...
MoeGia Posted 17 hours ago Share Posted 17 hours ago I didn't open you file but I have seen that. In my case it was related to copying dimensions with the detail. From Brian in July 2024: 'I was able to reproduce the issue and I have logged a report in our database.The problem is related to the dimensions. Anytime you group select dimensions with text the issue seems to occur.' Please send it in so it gets fixed. 1 Link to comment Share on other sites More sharing options...
Gawdzira Posted 15 hours ago Author Share Posted 15 hours ago Thanks. Link to comment Share on other sites More sharing options...
ComputerMaster86 Posted 10 hours ago Share Posted 10 hours ago I believe I have experienced this in the past. I should have created a report when it happened. Link to comment Share on other sites More sharing options...
