PitMan71 Posted June 5, 2025 Share Posted June 5, 2025 All On layout automatic elevation labels how do change the font for the view scale? I can change the callout and label font all day but the scale font persists and I am having trouble finding what directive is determining it. Thanks Shane Link to comment Share on other sites More sharing options...
DBCooper Posted June 5, 2025 Share Posted June 5, 2025 Post a picture of what you want to change. 1 Link to comment Share on other sites More sharing options...
PitMan71 Posted June 5, 2025 Author Share Posted June 5, 2025 Link to comment Share on other sites More sharing options...
Solution DBCooper Posted June 5, 2025 Solution Share Posted June 5, 2025 Open the layout box dialog and go to label page. Click on "edit" button next to "use callout". On callout label dialog, go to "attributes". There should be some controls for the text above the line and below the line. You can set it to match the callout text style or use a different text style if you want. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 5, 2025 Share Posted June 5, 2025 Here's what I use: The Main Text Style controls the Callout and the above line and below line take care of the others. Here's an example: I have this set in defaults for Layout Box Labels so it's automatic for anything I send to Layout. Some of the macros are for other things labeled in Elevations and Sections (wall finish materials, etc) that depend on the view type. 1 Link to comment Share on other sites More sharing options...
PitMan71 Posted June 5, 2025 Author Share Posted June 5, 2025 Thanks to you both. As is usual for me.... This was hidden in plain sight. Thanks again for the direction. Link to comment Share on other sites More sharing options...
