raltd9245 Posted June 4, 2025 Share Posted June 4, 2025 I messed up I reset to defaults can I get my chief back to where it was Please!!! Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 4, 2025 Share Posted June 4, 2025 in x17 you can import defaults from any previous plan. Link to comment Share on other sites More sharing options...
raltd9245 Posted June 5, 2025 Author Share Posted June 5, 2025 how Link to comment Share on other sites More sharing options...
VHampton Posted June 5, 2025 Share Posted June 5, 2025 Hi ralt9245, Don't worry — you can definitely recover your previous defaults in Chief Architect X17. Here's how to import defaults from an older plan: Step-by-Step: Restore Defaults from a Previous Plan Open a New Plan (or the plan where you reset the defaults). Go to the "File" menu. Select "Import" > "Defaults". Browse to a plan file (.plan) or layout file (.layout) you created before the reset. Chief will give you options to import different types of defaults (Dimensions, Walls, Roofs, etc.). Select what you want to restore and hit OK. This will overwrite your current defaults with the ones from the chosen file. Tip: If you had saved a custom template plan before resetting, that's also a great source to import from. 2 Link to comment Share on other sites More sharing options...
