PitMan71 Posted May 23, 2025 Share Posted May 23, 2025 How would achieve a look like the inset interior door on this pantry? Thanks Link to comment Share on other sites More sharing options...
DBCooper Posted May 26, 2025 Share Posted May 26, 2025 I would try using two walls. I would make a doorway on the one side with no casing and no jamb. The pantry door can then be marked as "not through". You could also try it without the doorway and mark the pantry door as "enlarged" but I think this will always make the opening the same size as the casing which may not be what you need. 1 Link to comment Share on other sites More sharing options...
Solution robdyck Posted May 26, 2025 Solution Share Posted May 26, 2025 I would model that using 2 walls adjacent to each other. In this example I used a 2X3 interior wall butted against the adjacent wall. For final plan views, I'd use a cad mask to cover wall fills. 2 Link to comment Share on other sites More sharing options...
PitMan71 Posted May 27, 2025 Author Share Posted May 27, 2025 Thanks for the help with this. You guys are awesome! Link to comment Share on other sites More sharing options...
