Global Cabinet Color Change
Seadust
Default Settings -> Materials.  Assuming that all of your cabinets are set to use the plan material defaults.
If not, then you can use the material painter (or eyedropper), and then click on the button for either "room mode" , "floor mode", or "plan mode".
Here is some more info:
https://www.chiefarchitect.com/support/article/KB-00793/using-the-different-material-painter-modes.html
https://www.chiefarchitect.com/videos/watch/5439/choosing-material-painter-modes.html?playlist=170
