Door opening not showing in foundation plan.
Depends on the height of the man door.  If it is above the foundation wall, it won't show an opening in the foundation plan.  If that's not the problem, then post the plan like Shane says.
Did you originally place the door on the floor above and then drag it down?  If so, then delete it and place a new one on the right floor.  If not, then post the plan.
I figured it out.  My walls were kind of wonky.  I changed them to the correct wall and it worked.  By the way, javatom, I have never had to put the doors on the foundation level for the foundation to show the opening.
