winterdd Posted April 21, 2025 Share Posted April 21, 2025 This has probably been asked before. Since we have options for frieze boards at the top of the wall is their an option in CA to get trim boards at the bottom of the wall without having to do 3d molding polylines around the home? I have always drawn them manually with the general framing tool but want to make different profiles now kind of like my window lintel type. Link to comment Share on other sites More sharing options...
joey_martin Posted April 21, 2025 Share Posted April 21, 2025 Select the "room" just outside the exterior walls and hit the button to make a room molding polyline. Add your profile from there. This method will automatically cut your openings for you as well. 1 Link to comment Share on other sites More sharing options...
Renerabbitt Posted April 21, 2025 Share Posted April 21, 2025 3 hours ago, winterdd said: wall without having to do 3d molding polylines around the home? You could do it with a pony wall, set it to 0" elevation and only show upper wall in plan view and set your pony wall to be thicker and align on inner surface 1 Link to comment Share on other sites More sharing options...
winterdd Posted April 22, 2025 Author Share Posted April 22, 2025 Thanks guys! Link to comment Share on other sites More sharing options...
Rookie65 Posted April 23, 2025 Share Posted April 23, 2025 You could also try "Wall Covering" for the exterior only. I use hardie trim in arctic white, and adjust the location height. Link to comment Share on other sites More sharing options...
