WebkatDesign Posted Wednesday at 11:17 PM Share Posted Wednesday at 11:17 PM When I start a new plan and I go to draw a wall, it does NOT show me the dimensions as I am drawing the wall. How can I change that? Link to comment Share on other sites More sharing options...
DBCooper Posted Wednesday at 11:59 PM Share Posted Wednesday at 11:59 PM See if you accidently turned off your "temporary dimensions". Look for it on your right side toolbar (if you are using the default toolbar setup) or in the "view" menu. 1 Link to comment Share on other sites More sharing options...
WebkatDesign Posted Thursday at 12:03 PM Author Share Posted Thursday at 12:03 PM thank you that was it Link to comment Share on other sites More sharing options...
WebkatDesign Posted Thursday at 12:30 PM Author Share Posted Thursday at 12:30 PM one more question, all these adjustments under "Dimensions" are NOT showing up on my screen (see image attached) how can I activate them? Link to comment Share on other sites More sharing options...
Chrisb222 Posted Thursday at 01:32 PM Share Posted Thursday at 01:32 PM 1 hour ago, WebkatDesign said: one more question, all these adjustments under "Dimensions" are NOT showing up on my screen (see image attached) how can I activate them? That video is from an older version and those settings have been relocated. Auto Exterior Dimensions now adopt the settings of the currently selected Dimension Default. You'll find those settings within each individual Dimension Default, in the Locate Auto Exterior panel. This was changed to allow more control over how Auto Exterior Dimensions are generated, which is now based on which Dimension Default is currently active instead of a single global setting. 1 Link to comment Share on other sites More sharing options...
WebkatDesign Posted Thursday at 02:00 PM Author Share Posted Thursday at 02:00 PM So would that be the same for the NKBA dimensions button that they refer to at the bottom menu? Link to comment Share on other sites More sharing options...
Chrisb222 Posted Thursday at 02:06 PM Share Posted Thursday at 02:06 PM 4 minutes ago, WebkatDesign said: So would that be the same for the NKBA dimensions button that they refer to at the bottom menu? The stock X16 Residential Template file has a "Kitchen and Bath Dimension Default" which conforms to NKBA, and has more flexibility than the old NKBA settings. Check for it under your Dimension Defaults. 1 Link to comment Share on other sites More sharing options...
