Jambruins Posted 19 hours ago Share Posted 19 hours ago Attached is my plan. I am having some issue with siding/drywall/etc on some walls so I am thinking I may not have set this house up the right way. 11' tall walls on 1st floor. 8' tall walls on 2nd floor for the middle section on two sides using space under rafters so 0' wall height at exterior wall and increasing in height as you moved toward the center Thanks for the help. house.zip Link to comment Share on other sites More sharing options...
Mark3D Posted 4 hours ago Share Posted 4 hours ago Give this a go your model is way of zero position see if it helps Shaw garage.zip Link to comment Share on other sites More sharing options...
