Stairs Open Rail Transition to Between Walls
PitMan71
Go to solution Solved by SNestor,
You need to put in a "complete break" instead of a normal break.  What you have now is one stair section with 2 sub-sections and you need two different stair sections.  Once you have two stair sections you can make them different widths.
Here is some more info:
https://chieftalk.chiefarchitect.com/topic/25690-stairs-complete-break-tool/
