PitMan71 Posted April 1, 2025 Share Posted April 1, 2025 I have a straight stair that I want the lower portion to have open rail. BUT I want it to transition to between walls as it goes through the floor. Is there a way to break a continuous stair to have open rail to a certain point and then transition to between walls? Thanks in advance. Chelsea.plan.zip Link to comment Share on other sites More sharing options...
DBCooper Posted April 1, 2025 Share Posted April 1, 2025 You need to put in a "complete break" instead of a normal break. What you have now is one stair section with 2 sub-sections and you need two different stair sections. Once you have two stair sections you can make them different widths. Here is some more info: https://chieftalk.chiefarchitect.com/topic/25690-stairs-complete-break-tool/ 1 Link to comment Share on other sites More sharing options...
Solution SNestor Posted April 1, 2025 Solution Share Posted April 1, 2025 Take a look at the attached plan.... I added a second floor. Used the complete break tool on the stair. Made the wall under the stair a "partition wall" so that the upper wall end is covered with drywall. 1 Link to comment Share on other sites More sharing options...
SNestor Posted April 1, 2025 Share Posted April 1, 2025 Here is the plan...forgot to attach on my previous post; Chelsea - Fixed.plan.zip Link to comment Share on other sites More sharing options...
PitMan71 Posted April 1, 2025 Author Share Posted April 1, 2025 Y'all are the best there is! Thank you. Shane Link to comment Share on other sites More sharing options...
