Exterior Wall Framing
teresa
Go to solution Solved by teresa,
My exterior wall framing is not building and it does not have a button and the bottom button to build separately is missing.  any ideas?
Open your plan,  select exterior wall,  open wall definition,  do you see a stud framing layer?  No.  That is the  problem.
Open interior wall,  do you see a layer with stud framing?  Yes,  that is why you have framing there.
Stop screwing around with CA's default walls until you know what you are doing.
Well Mr. Hall,  I didn't mess with defaults.  I've been doing this for awhile and it is not something I thought to check.  Your answer helped, but your rudeness did not.
I am very sorry Mss Clifford,  I did not mean to be rude and I did not understand you were experienced and had been doing this for awhile.  I thought you were inexperienced so I was trying to help out someone I perceived as being relatively new.
No problem,  I will stay off your threads from now on.
