Renerabbitt Posted Thursday at 04:22 AM Share Posted Thursday at 04:22 AM What's your method? Link to comment Share on other sites More sharing options...
Gawdzira Posted Thursday at 04:57 AM Share Posted Thursday at 04:57 AM Block, raise, unblock. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted Thursday at 05:01 AM Share Posted Thursday at 05:01 AM Select single Wall Cabinet, Marquee Select Similar, Select All Similar, Transform Replicate, Move 2" in Z direction, Okay. 1 Link to comment Share on other sites More sharing options...
Renerabbitt Posted Thursday at 12:33 PM Author Share Posted Thursday at 12:33 PM 7 hours ago, Alaskan_Son said: Select single Wall Cabinet, Marquee Select Similar, Select All Similar, Transform Replicate, Move 2" in Z direction, Okay. Sorry It was late. I meant to raise the height of the cabinet itself when you have different height cabinets Link to comment Share on other sites More sharing options...
Gawdzira Posted Thursday at 03:50 PM Share Posted Thursday at 03:50 PM I am not answering and more questions before I can speak with counsel. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted Thursday at 04:24 PM Share Posted Thursday at 04:24 PM 3 hours ago, Renerabbitt said: Sorry It was late. I meant to raise the height of the cabinet itself when you have different height cabinets I see. Make all cabinets 2" taller. I'm not sure I have a specific method for doing this in any specifically efficient way. I guess it depends on how many cabinets of different heights I have. One way or another though I would likely just group select cabinets based on specific heights and change the heights one group at a time. As far as selecting those groups... If I immediately knew where they were, I might just manually group select, If I knew off the top what the different heights were, I might use the Match Properties tool to group select, otherwise, I might use a temp schedule to group select by height. 1 Link to comment Share on other sites More sharing options...
Renerabbitt Posted Thursday at 04:43 PM Author Share Posted Thursday at 04:43 PM 19 minutes ago, Alaskan_Son said: I see. Make all cabinets 2" taller. I'm not sure I have a specific method for doing this in any specifically efficient way. I guess it depends on how many cabinets of different heights I have. One way or another though I would likely just group select cabinets based on specific heights and change the heights one group at a time. As far as selecting those groups... If I immediately knew where they were, I might just manually group select, If I knew off the top what the different heights were, I might use the Match Properties tool to group select, otherwise, I might use a temp schedule to group select by height. Which leads me to, we should be able to add +2 to "No Change" Link to comment Share on other sites More sharing options...
Alaskan_Son Posted Thursday at 04:56 PM Share Posted Thursday at 04:56 PM 12 minutes ago, Renerabbitt said: Which leads me to, we should be able to add +2 to "No Change" Yes. I can’t tell you how many times I’ve tried some variation of that over the years hoping that I can get it to work somehow. Link to comment Share on other sites More sharing options...
Gawdzira Posted Thursday at 05:38 PM Share Posted Thursday at 05:38 PM Ohh, now I remember. I add +2" to No Change and then scream an expletive. Link to comment Share on other sites More sharing options...
