SHCanada2 Posted March 19 Share Posted March 19 CA decided to make a cabinet through the wall. Any ideas how to stop it? I cant even select it The bump out is a cantilever. the walls look normal: 18.03.2025_18.50.23_REC.mp4 Link to comment Share on other sites More sharing options...
JiAngelo Posted March 19 Share Posted March 19 That's a countertop. Manually draw the countertop over the cabinets should eliminate that. You may need to replace the sink. Link to comment Share on other sites More sharing options...
SHCanada2 Posted March 19 Author Share Posted March 19 merci Link to comment Share on other sites More sharing options...
Solution DBCooper Posted March 19 Solution Share Posted March 19 Quote That's a countertop. Manually draw the countertop over the cabinets should eliminate that. You may need to replace the sink. I don't think that is right. Even if it was a counter top problem, I don't think you need to replace the sink when you replace an auto counter with a custom one. My guess is that you have accidently created a weird cabinet connection situation. Try going into your general cabinet defaults and turning off "create auto fillers for angled connected cabinets". You may or may not want to turn off the "create auto blind corner cabinets" too. If that doesn't solve the problem, then you should post your plan. 1 Link to comment Share on other sites More sharing options...
SHCanada2 Posted March 19 Author Share Posted March 19 52 minutes ago, DBCooper said: My guess is that you have accidently created a weird cabinet connection situation. Try going into your general cabinet defaults and turning off "create auto fillers for angled connected cabinets". You may or may not want to turn off the "create auto blind corner cabinets" too. that fixed it thanks Link to comment Share on other sites More sharing options...
JiAngelo Posted March 19 Share Posted March 19 My bad. I also didn't know that setting existed. When I drew a custom countertop it still left the back of that cabinet hanging outside the wall. It only happens to one of the cabinets. The other truncates properly. Link to comment Share on other sites More sharing options...
