Columns - Plan view
PitMan71
I am using some stock columns from the library that have a cap and base that's wider than the actual column. Is there a way to have the columns display in plan view such that the width is the actual column and not that of the base and cap? For instance I have 8" square columns on the plan, but they show up like 12".
Thanks in advance.
Okay
55 minutes ago, MPDesign said:
Try editing the 2d cad block of the column first?
once you do that and change the size it will adjust the plan view as well.
I will try that.... Didn't know you could edit the 2d block display. Thanks.
Hi Shane,
I'm not sure I understand, 2d plan view display doesn't affect the elevation of the column.
If you want to edit the column size use the doorway icon on the left of the tool bar.
-Procedure for editing the 2d plan view-
Place your library column in plan view, select it, then open this icon
