mtldesigns Posted March 5 Share Posted March 5 I have a 3-planed ceiling, not really a cathedral, I need to put T&G pine on this in the direction showed because of the ceiling framing. How do I get this pattern to line up? I had thought to create a new material and adjust the center plane in the direction it needed to go, BUT when I do that, all three planes change... its acting as one. I did this ceiling using ceiling planes. Any ideas how to align? Thanks in advance Link to comment Share on other sites More sharing options...
tundra_dweller Posted March 5 Share Posted March 5 Michael, I think selecting for "Global Symbol Mapping" in the material definition pattern tab will get you there. Otherwise you can create a copy of the material by changing the scoping of the adjust material definition tool to anything but "Plan" mode and you should get a prompt to create a copy of the material that you can then adjust independently of the original material. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 6 Share Posted March 6 On 3/5/2025 at 1:35 PM, mtldesigns said: I had thought to create a new material and adjust the center plane in the direction it needed to go, BUT when I do that, all three planes change You need to make at least 2 materials, perhaps 3 for 3 planes, just make copies of original material named _1 _2 _3 etc etc so you can offset each plane individually ... similar trick is needed for tile in a shower sometimes for the 3 different walls... (using materials regions) M. Link to comment Share on other sites More sharing options...
