mtldesigns Posted March 5, 2025 Share Posted March 5, 2025 I have a 3-planed ceiling, not really a cathedral, I need to put T&G pine on this in the direction showed because of the ceiling framing. How do I get this pattern to line up? I had thought to create a new material and adjust the center plane in the direction it needed to go, BUT when I do that, all three planes change... its acting as one. I did this ceiling using ceiling planes. Any ideas how to align? Thanks in advance Link to comment Share on other sites More sharing options...
tundra_dweller Posted March 5, 2025 Share Posted March 5, 2025 Michael, I think selecting for "Global Symbol Mapping" in the material definition pattern tab will get you there. Otherwise you can create a copy of the material by changing the scoping of the adjust material definition tool to anything but "Plan" mode and you should get a prompt to create a copy of the material that you can then adjust independently of the original material. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 6, 2025 Share Posted March 6, 2025 On 3/5/2025 at 1:35 PM, mtldesigns said: I had thought to create a new material and adjust the center plane in the direction it needed to go, BUT when I do that, all three planes change You need to make at least 2 materials, perhaps 3 for 3 planes, just make copies of original material named _1 _2 _3 etc etc so you can offset each plane individually ... similar trick is needed for tile in a shower sometimes for the 3 different walls... (using materials regions) M. Link to comment Share on other sites More sharing options...
