Curved cabinets with curved drawers/doors
KevinMyers
I see in the properties of the cabinet, in the "box construction" tab, cabinet corner treatment where you can round the corners. BUT you can't add drawers there that I can tell. Might have a play around with that feature to see where it leads.
You can get kind of close using a left and right "radius end cabinet".  I don't think there is any easy way to get the asymmetrical curved drawers though.
4 hours ago, KevinMyers said:
Anyone have any ideas on how to make cabinets in Chief similar to the attached pics?
Using two cabinets and custom door symbols for the front corner cabinets you can make it look ok in 3D standard and PBR (note change reveal between those cabinets to zero). Hardware on corners placed manually/
For vector and elevation plot would need clean up lines in layout.
Did not mess with the valance base but similar solution or solids.
