Load time of rear elevation
Steve_Nyhof
Anyone know of a way to find out why this rear elevation takes so long to load? I've had hatch patterns that take some time, but this is a normal hatch pattern. It is a larger home but there is nothing special going on with the rear elevation. As far as a know things were fine several weeks ago, but now that I open it again it is taking a long time to generate.
https://drive.google.com/file/d/1jV7ciZ5kKl3RlMhlDu3jNUWVwwJX1o-y/view?usp=sharing
Thank you,
Steve
Correction update: All elevations
I shut my furniture off and my roof. I am trying to add manual grills to my arched window and every click I make takes forever.
36 minutes ago, GeneDavis said:
Taking me about 18 seconds to load any of the four.
hmmm. That is still a bit of a long time to load an elevation although less than what I am getting. I made  copy of the file and plan to slowly remove things to try and find the issue.
I would say that from 2000 to over 6000 sq.ft. homes load my elevations in like 5 seconds, maybe 10 at most. Something is in this file I need to find.
Just out of curiosity, I merged all the materials together so there is only 1 material.  I wanted to see if their was still a lag with the 3D model in your elevation views.  That did speed up the load time of the elevation views.  I am guessing if you have some method of condensing and cleaning up the materials so their is not so many that may help speed up the load times.  I wasn't able to pin point any specific textures causing the slow down.
11 minutes ago, robdyck said:
On my machine, the slab material pattern was the culprit.
Good catch! You know for some reason my plan was missing the pattern on some of the concrete. I updated it with a concrete pattern but that did not fix the loading. Can you let me know what you found specifically?
Its funny. It is a paver material and yet you cannot see the pattern as a paver from the plan view. (You would add a hatch pattern to see a pattern in plan view). When I put the material on a wall the elevation still loads fast. It mush be that in elevation when used as a paver (flat) all those pattern lines are stacked on top of each other horizontally, guessing. Since I will never use a paver on a wall, I think I will remove the patterns from my common pavers as I have never used the patterns anyway. My guess is that I have used it in the past but maybe smaller areas and the elevation loaded more slowly but must have been tolerable.
