Ed_Orum Posted February 15, 2025 Share Posted February 15, 2025 Hello, Does Chief have a wall surface for Pine V Joint Paneling (both horizontal and vertical)? I am drawing a few cabin plans and the interior walls want to be V Joint paneling. Thanks in advance. Lane Link to comment Share on other sites More sharing options...
Gawdzira Posted February 15, 2025 Share Posted February 15, 2025 Link to comment Share on other sites More sharing options...
DBCooper Posted February 16, 2025 Share Posted February 16, 2025 If you want vertical ones in your user library, you can just make a copy of the horizontal ones that are in the Chief library and then change the texture and pattern angle to 90 degrees. You can also do this in the plan (if you only need the vertical ones) by just editing the plan material using the "adjust material definition" (aka rainbow) tool Link to comment Share on other sites More sharing options...
Ed_Orum Posted February 17, 2025 Author Share Posted February 17, 2025 Thanks! Link to comment Share on other sites More sharing options...
