Ed_Orum Posted February 10 Share Posted February 10 Apparently Chief thinks siding should not cover the sill plate, so in all of the elevation views, the siding starts above the sill plate. Is there a setting to make the siding start 1/2" below the sill plate so it covers the foundation top by 1/2"? Thanks in advance, Lane 1 Link to comment Share on other sites More sharing options...
KilianDrafting Posted February 10 Share Posted February 10 Make sure your exterior wall type Main Layer has framing CHECKED under the material properties tab. If it is unchecked the siding will not cover the sill plate. You can also specify the extension of the siding layer in this same wall definition dialogue. Link to comment Share on other sites More sharing options...
Ed_Orum Posted February 11 Author Share Posted February 11 Thanks. It was not checked, so I checked it. Still no change, the siding does not cover the sill plate. Unless I am seeing it wrong, but even though the sill plate is the same exterior color as the siding, I still see the 1-1/2" sill plate, then the full height siding in all elevation views. I do not see any options for extending the siding in the dialogue box. Link to comment Share on other sites More sharing options...
KilianDrafting Posted February 11 Share Posted February 11 Did you make sure to select the main layer of the wall type? Each layer has separate material properties, and when dialogue is opened it defaults to the exterior layer. Link to comment Share on other sites More sharing options...
KenL-sdd Posted February 11 Share Posted February 11 @Ed_Orum Typically when I see this issue its due to the foundation wall below. I have had this issue many times. Post your plan and I will take a look Link to comment Share on other sites More sharing options...
Ed_Orum Posted February 11 Author Share Posted February 11 I closed the program down, opened it up again and the settings took effect. Thanks for the offer. Lane Link to comment Share on other sites More sharing options...
Ed_Orum Posted February 11 Author Share Posted February 11 10 hours ago, KilianDrafting said: Did you make sure to select the main layer of the wall type? Each layer has separate material properties, and when dialogue is opened it defaults to the exterior layer. Yup. I shut the program down, opened it up again and it showed up correctly. --Lane Link to comment Share on other sites More sharing options...
