Siding Does Not Cover Sill Plate
Ed_Orum
Apparently Chief thinks siding should not cover the sill plate, so in all of the elevation views, the siding starts above the sill plate.
Is there a setting to make the siding start 1/2" below the sill plate so it covers the foundation top by 1/2"?
Thanks in advance,
Lane
Thanks.
It was not checked, so I checked it.  Still no change, the siding does not cover the sill plate.  Unless I am seeing it wrong, but even though the sill plate is the same exterior color as the siding, I still see the 1-1/2" sill plate, then the full height siding in all elevation views.
I do not see any options for extending the siding in the dialogue box.
10 hours ago, KilianDrafting said:
Did you make sure to select the main layer of the wall type?
Each layer has separate material properties, and when dialogue is opened it defaults to the exterior layer.
Yup.  I shut the program down, opened it up again and it showed up correctly.
--Lane
