ValleyGuy Posted February 6, 2025 Share Posted February 6, 2025 Does anyone have an idea how to delete these once they are added? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 6, 2025 Share Posted February 6, 2025 Not sure about Mac, but on Windows, you can't delete them but what you can do is simply click and drag another white or gray filler color to replace them. You might also try dragging them and dropping them outside the dialog to see if that removes them (kinda like we do for tools on the toolbar). Link to comment Share on other sites More sharing options...
ValleyGuy Posted February 6, 2025 Author Share Posted February 6, 2025 1 hour ago, Alaskan_Son said: Not sure about Mac, but on Windows, you can't delete them but what you can do is simply click and drag another white or gray filler color to replace them. You might also try dragging them and dropping them outside the dialog to see if that removes them (kinda like we do for tools on the toolbar). I tried both of those ideas, unfortunately neither worked. Over top just pushes the lower one away to open up a fresh clean space. Dragging outside and releasing just lets me see it zoom back into position again. RH click doesn't do anything. I'm really at a loss. Thanks though. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 6, 2025 Share Posted February 6, 2025 Try dragging them to your Trash bin. 1 Link to comment Share on other sites More sharing options...
Solution glennw Posted February 6, 2025 Solution Share Posted February 6, 2025 Selecting the color in the small box and hitting Delete works for me. This works in most cases and I would need to have more of a play to see under what circumstances it doesn't work. Link to comment Share on other sites More sharing options...
ValleyGuy Posted February 7, 2025 Author Share Posted February 7, 2025 Thank you @glennw, sounds so straight forward when someone else says it! Link to comment Share on other sites More sharing options...
ValleyGuy Posted February 7, 2025 Author Share Posted February 7, 2025 1 hour ago, Alaskan_Son said: Try dragging them to your Trash bin. This also works! Thanks Michael Link to comment Share on other sites More sharing options...
