CCMckeeHomes11 Posted Monday at 06:19 PM Share Posted Monday at 06:19 PM any idea on how to square up and outside corner cabinet so it doesn't have the radius fronts on them Link to comment Share on other sites More sharing options...
Renerabbitt Posted Monday at 06:22 PM Share Posted Monday at 06:22 PM 3 minutes ago, CCMckeeHomes11 said: cabinet so it doesn't have the radius fronts on them Are you using a radius end cabinet? Use an angled cabinet instead Link to comment Share on other sites More sharing options...
CCMckeeHomes11 Posted 19 hours ago Author Share Posted 19 hours ago Tried that first. The Angle Cabinet doesn't come in at a 90 deg it breaks it into two 45s. I'm after more of a lazy susan outside corner with door on both outside panels Link to comment Share on other sites More sharing options...
Alaskan_Son Posted 18 hours ago Share Posted 18 hours ago Use a normal cabinet with a custom side. 1 Link to comment Share on other sites More sharing options...
DBCooper Posted 6 hours ago Share Posted 6 hours ago I would make either the left or right side "match front" and then turn off "flat sides" for the toe kick, and that should get you close to the look you want. The nice thing about the "match front" is that when you modify the front face then the other side will update automatically. Link to comment Share on other sites More sharing options...
