CCMckeeHomes11 Posted February 3, 2025 Share Posted February 3, 2025 any idea on how to square up and outside corner cabinet so it doesn't have the radius fronts on them Link to comment Share on other sites More sharing options...
Renerabbitt Posted February 3, 2025 Share Posted February 3, 2025 3 minutes ago, CCMckeeHomes11 said: cabinet so it doesn't have the radius fronts on them Are you using a radius end cabinet? Use an angled cabinet instead Link to comment Share on other sites More sharing options...
CCMckeeHomes11 Posted February 4, 2025 Author Share Posted February 4, 2025 Tried that first. The Angle Cabinet doesn't come in at a 90 deg it breaks it into two 45s. I'm after more of a lazy susan outside corner with door on both outside panels Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 4, 2025 Share Posted February 4, 2025 Use a normal cabinet with a custom side. 1 Link to comment Share on other sites More sharing options...
DBCooper Posted February 5, 2025 Share Posted February 5, 2025 I would make either the left or right side "match front" and then turn off "flat sides" for the toe kick, and that should get you close to the look you want. The nice thing about the "match front" is that when you modify the front face then the other side will update automatically. 1 Link to comment Share on other sites More sharing options...
