Timber Trusses (with SketchUp)
Medeek
1 hour ago, GaryOhmer said:
both in sketchup and chief if possible
Chief already does an automatically framed common sill on mulled windows, so you would just manually place your 2x4 cripple/trim
  • Downvote 1
On 6/24/2025 at 9:39 AM, GaryOhmer said:
In the advanced framing options for windows - common sill for ganged windows plus would be nice to be able to use 2x4 in between windows in 2x6 wall
I'm not sure exactly what you are describing here, but I can give it some consideration.  Please send me a screenshot or two, usually a picture clears things up immediately.
On a different note I am currently working on a new plugin called "Medeek HVAC" for SketchUp.  This one should be interesting.  I'm curious if Chief has any tools for working with HVAC systems, primarily with ductwork?
The same duct assembly but with different profiles:
There will be numerous assets that will be included within this plugin.  AC condenser units like the ones shown are a good example of such assets.
Note that any asset that is included within my plugin(s) is personally modeled by me and inspected.  It has to be free of any stray geometry, a SketchUp solid (or solids), dimensionally accurate and have as low of poly count as possible while still providing a realistic representation.
On 6/17/2025 at 7:32 PM, para-CAD said:
Thanks for your insane ruby work, Nathan.  Keep up the great work!
Thank-you for the vote of confidence, it is greatly appreciated.  I think most Chief users realize that what I do is simply adding more tools into their already well equipped tool bag that is Chief Architect,  Just another resource if needed.  I'm not trying to supplant Chief or say that SketchUp is even better, that is not my goal.  However, some things are just easier to deal with in SketchUp so why not use the geometry and bring it into Chief as needed.
Think of it this way, I don't paint a picture with a pencil and I don't write a letter with a brush.  We select the appropriate tool to match the job.
I think the down voters are just those very few individuals who feel threatened by what can be done within SketchUp, which is an exceptional 3D modeler.  However, rather than feel threatened just realize that SketchUp can potentially augment your experience in Chief, you can up your game to the next level and even save some time in the process.
On a slightly different note here are some more screenshots of the new HVAC plugin as I throw the kitchen sink at it:
265400629_CleanShot2025-06-28at21_59_00.thumb.png.afde99444621aa74289eb25de857fbd9.png
I am right there with you.....if I need a 3D accurate detail, I will create it in sketchup then bring it over to chief.
Chief Architect is the most efficient and best looking construction doc maker (layout) for plans for permit.
I like to use Note schedules to keep the image as clean as possible so the framers have maximum information....images and text.
SketchUp is able to model anything...accurately.
I don't know enough about HVAC install to make good plans, but I bet an HVAC tech could redline so pages if I needed to support such design work.
Great tools, Nathan!
Those details are stunning.  Very nice work.  I would say your details are easily on par with anything Nick Sonder puts out and he has been the SketchUp detail king for some years now.
1326561418_CleanShot2025-07-01at12_33_26.thumb.png.70fbad3f93dc446bfb3ff97bd384ea58.png
Chief needs help.
There is so much wrong with the wall detail tool. This is out of the box and looks like it requires some tweaking. I have never set any of the settings to generate this kind of garbage. There is software that gives very accurate framing information but the company has the absolute worst customer service and software leasing policy that I refuse to ever use it again. It would be nice if chief could buy them out or at least start to generate wall panel and roof framing cut sheets as part of interpreting an accurate 3-D model.
2101769408_CleanShot2025-07-01at12_40_47.thumb.png.48cd494d31cee02c0c2c8d3875cde4e1.png
Until such time as chief creates this kind of wall panel and roof framing accuracy, I will continue to use sketchup and occasionally AutoCAD.
Probably....its Safari
Thanks for wanting to help me with this.............when I see you girding up for digital combat.....to bring order to the computing realm.......this is the soundtrack in my head
I couldn't get the video to load either, the audio is there but no visuals, strange.
Anyhow, I can see the framing is all messed up, not sure what is happening there.  This isn't a terribly complicated wall so I'm assuming Chief has an answer for it, maybe you somehow misconfigured it?  However, you being as experienced a Chief user as you are I kind of doubt that is the issue here.
I'm now starting on Transitions and Tees for the Medeek HVAC plugin, this is getting more interesting:
If Chief has no specialized system for HVAC or ducting then importing a complete duct network from SketchUp may be a good solution.
  • Downvote 1
The next few days will be spent checking and double checking that the transition algorithms are robust and can handle all of the adjustments that get thrown at them. Overall they aren't too complicated, however when you start adding in offsets and rotations things can change very quickly.
This morning I started with offsets and size differences for a RECT-RECT transition, which is by far the simplest of all the transition permutations. There are three different duct profiles which then yield six different possible combinations at any given transition, and each one needs to be tested and checked:
RECT-RECT
RND-RND
OVAL-OVAL
RECT-RND
RECT-OVAL
RND-OVAL
(The text labels shown are just my temporary debugging markers so that I can track my points)
Adding a rotation to a duct segment is probably going to be the worst case scenario in all of this, but I'm sure I can figure it out eventually.
  • Downvote 1
The following toolbar will be added for HVAC Appliances:
hvac_app_su_menu_active
The HVAC Appliance tool will be for adding AC units, furnaces, fans, VAV’s, boilers etc… Essentially any preconfigured HVAC equipment that is not duct work.
The will be simple stand alone assemblies that one can reposition using the native tools.
  • Downvote 1
I like that Nathan is excited / motivated to share his ruby magic to make sketchup much more automated and accurate.......his tools make people more productive, faster.
Combining the strengths of Chief and Sketchup is real design power.
I don't understand the 1-app only cult thinking...........oh wait.........third party rendering apps.
Seems a bit hypocritical
If sketchup isn't for you...............move along......but then again, pay something into 3D warehouse......those people are designers too.
Pass any the expense to your clients.
I wish everyone a great and successful week.
GO GET SOME!!!
I’ve added a manufacturer parameter to the appliances menus since the number of part numbers is going to be so large I think it only makes sense to break these drop down boxes up a bit by “type” and “manufacturer”. There will also be a “generic” option for those parts/appliances that do not have a manufacturer’s logo affixed.
Modeling these various HVAC appliances is a bit tedious since I first have to find somewhat detailed literature or documentation so I can at least get them dimensionally accurate. Some of the features modeled are my best guesses based on images found online since not everything is specifically dimensioned within the manufacturer’s documentation.
I also try to keep the models fairly low poly but typically there is not more than one or two of these appliances within a given model (for residential projects), so I am not as concerned as I am with HVAC fittings.
2 minutes ago, GaryOhmer said:
2 x 4 cripples in between the windows
If you are asking for chief to do this automatically I would put it in suggestions, or are you using sketchup and are asking for nathan to make it work in his sketchup plugins?
Version 0.9.0 - 07.10.2025
Created the Medeek HVAC Plugin, utilizing SketchUp’s Ruby API.
Added tools to create ductwork, fittings, and HVAC appliances (AC, furnaces, and heat pumps).
The BETA version is out, you can now download the trial version here:
http://design.medeek.com/calculator/sketchup/medeek_hvac_ext.rbz
Please be advised this is the very first release of the extension and there will be many fires to put out.
