vikiw_bend Posted January 31, 2025 Share Posted January 31, 2025 There are a number of different types of grass to use for grass regions, but when you create a grass region, you don't seem to be able to choose. What am I doing wrong? Or has anybody else dealt with this? Link to comment Share on other sites More sharing options...
DBCooper Posted January 31, 2025 Share Posted January 31, 2025 When you create a "grass region", the program generates the grass for you. You can change the way it looks by changing the various settings. If you have made one you like, you can add it to the library and then place it into other plans. You can't apply a grass material to it though. You can also create a normal terrain feature and apply a grass material to it. The grass region will look much more realistic though. Link to comment Share on other sites More sharing options...
vikiw_bend Posted January 31, 2025 Author Share Posted January 31, 2025 DB, That being said, why does Chief have a catalog of different kinds of grasses to choose from? If one wants to use a fescue, for example, there doesn't seem to be a way to select that. Link to comment Share on other sites More sharing options...
robdyck Posted January 31, 2025 Share Posted January 31, 2025 Select from the library (single click) and then place in plan view (another single click). It drops in as a 10'x10' polyline that you can then reshape. Link to comment Share on other sites More sharing options...
vikiw_bend Posted January 31, 2025 Author Share Posted January 31, 2025 Thank you Robert! So simple. I think I might have known how to do this but hadn't in a very long time. 1 Link to comment Share on other sites More sharing options...
robdyck Posted January 31, 2025 Share Posted January 31, 2025 @vikiw_bendGlad to help! Link to comment Share on other sites More sharing options...
DBCooper Posted February 1, 2025 Share Posted February 1, 2025 Just to be clear, Chief has some grass materials in the library and these can't be applied to grass regions but they can be applied to other objects, like terrain features. Chief also has a bonus library of grass regions that can be downloaded and then you can place them directly into a plan. You can also create your own custom grass regions in a plan and add them to your library for re-use in other plans. I misunderstood your original question and thought you were trying to apply a grass material to a grass region. Link to comment Share on other sites More sharing options...
