DRyeHD Posted January 29, 2025 Share Posted January 29, 2025 I'm not sure what I did but I've got a couple of rooms without floors. One is defined (garage), the other is not (dining). I noticed that the exterior room line has some overlaps that I don't think should be there. I've attached the file. If anyone can take a look and let me know what I did wrong, I'd sure appreciate it. Brunk.zip Link to comment Share on other sites More sharing options...
Solution Alaskan_Son Posted January 29, 2025 Solution Share Posted January 29, 2025 Wall connection issues: ...and for the garage, you have the floor set to be defined by the foundation room below but you don't have a properly defined room below it. Link to comment Share on other sites More sharing options...
TeaTime Posted January 29, 2025 Share Posted January 29, 2025 The porch is made up of a collection of room dividers and Invisible Attic Walls. Ditch the Room Dividers and adjust the attic walls to just be invisible walls. Link to comment Share on other sites More sharing options...
DRyeHD Posted January 30, 2025 Author Share Posted January 30, 2025 @Alaskan_Sonand @TeaTime thanks for the input. My customer wanted an elaborate porch then decided to go with what you saw. I guess that caused the dining room problem. As for the garage, I'll take a look at that. After five years of using CA I still have problems with foundations. I need to get my head wrapped around what all the DBX inputs do. Thank you both. Link to comment Share on other sites More sharing options...
