StephenM Posted January 26, 2025 Share Posted January 26, 2025 Hi, I am wondering how you get stairs on the side of a building, leading from ground level/main level to the second level, to show on the second floor plans? Is there a way to do it using the auto generate stairwell tool? I've included a couple photos for reference. Thanks! Link to comment Share on other sites More sharing options...
DBCooper Posted January 26, 2025 Share Posted January 26, 2025 There are at least two ways to do this. You can either use the "reference display" with a view that is setup to just show the stairs on the first floor (but it will show with an up arrow instead of a down arrow), or you could create a room using invisible walls and make it an "open below". 2 1 Link to comment Share on other sites More sharing options...
StephenM Posted January 26, 2025 Author Share Posted January 26, 2025 15 hours ago, DBCooper said: There are at least two ways to do this. You can either use the "reference display" with a view that is setup to just show the stairs on the first floor (but it will show with an up arrow instead of a down arrow), or you could create a room using invisible walls and make it an "open below". Okay thank you for that! Link to comment Share on other sites More sharing options...
StephenM Posted January 26, 2025 Author Share Posted January 26, 2025 20 hours ago, DBCooper said: There are at least two ways to do this. You can either use the "reference display" with a view that is setup to just show the stairs on the first floor (but it will show with an up arrow instead of a down arrow), or you could create a room using invisible walls and make it an "open below". Do I need create a room on both levels with invisible walls? Link to comment Share on other sites More sharing options...
Mark3D Posted January 26, 2025 Share Posted January 26, 2025 1 hour ago, StephenM said: Do I need create a room on both levels with invisible walls? No just the one you want to see through second 1 Link to comment Share on other sites More sharing options...
